JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
08.05.2008, 08:37 AM
Originally Posted by Ev1er View Post
thanks guys!
Is it an internal Bec in the Mamba max esc?
If not, where do I solder the CC BEC on the wiring?
You will want to solder the positive wire of the bec to the positive wire of the esc and the negative of thebec to the negative of the esc. MAKE SURE YOU REMOVE THE RED WIRE FROM THE PLUG THAT GOES TO THE RECEIVER AND TAPE OR HEAT SHRINK IT TO SO IT DOESN'T SHORT TO ANYTHING.
