Wanna make 5$ easy? Mamba Max ESC, CC BEC, 2 x 7.4v 2s 8k lipos wiring diagram!?
Ev1er
Wanna make 5$ easy? Mamba Max ESC, CC BEC, 2 x 7.4v 2s 8k lipos wiring diagram!? - 08.04.2008, 08:36 PM
Hi!
I got an e-revo with a MM ESC, CC BEC and two TrueRC 8k 2s lipos!
I have not soldered it yet, because I was not sure how to do it!
I don't want to solder the batteries in series, so I want to get two plugs on my esc so I can connect two batteries.
Where and how do I solder the CC BEC?
Can anyone draw a wiring diagram in paint or something?
I will donate 5$ with paypal to the person that can give me a very helpful wiring diagram.
Thanks
E-Traxxer
08.04.2008, 08:40 PM
http://www.scriptasylum.com/rc_speed/_wiring.html
This should help you.
Theres no need to put out a money reward on this forum though, I'm sure everyone here is willing to help you for free.
08.04.2008, 08:55 PM
He could donate the money to BrianG, he does provide that site for free, and it is very useful...
E-Traxxer
08.04.2008, 09:01 PM
Yeah, if anyone you should donate to him.
That site is extremely useful, I don't know what I'd do without it!
Probably just walk into a wall and hope for the cracks to show diagrams/calculations. I don't know if that would work very well though...
jayjay283
jayjay283's Avatar
08.04.2008, 09:03 PM
no doubt without that site I wouldnt know where to begin. Just click the donate button at the bottom of the page there and throw him the $5
Ev1er
08.04.2008, 09:17 PM
Thanks guys but that is not what I need.
Read this sentence one more time:
"I don't want to solder the batteries in series, so I want to get two plugs on my esc so I can connect two batteries"
Anyone can help me now?
Ev1er
08.04.2008, 09:20 PM
Sorry guys I was wrong!
That is excacly (how do I spell it? [From Norway]) what I need:;D
E-Traxxer
08.04.2008, 09:23 PM
Glad we could help!
Good luck with your Revo
Motoman
Motoman's Avatar
08.05.2008, 12:01 AM
You could also just make or buy a y-harness so that you don't have to solder anything to your new esc. That way you still have 2 separate batteries that you can wire in series with the y-harness and plug in one connector to the existing connector on the esc.
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.05.2008, 12:57 AM
Ditto, I am with kermit!
www.cubicle101.com
Ev1er
08.05.2008, 08:16 AM
thanks guys!
Is it an internal Bec in the Mamba max esc?
If not, where do I solder the CC BEC on the wiring?
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
08.05.2008, 08:37 AM
Originally Posted by Ev1er View Post
thanks guys!
You will want to solder the positive wire of the bec to the positive wire of the esc and the negative of thebec to the negative of the esc. MAKE SURE YOU REMOVE THE RED WIRE FROM THE PLUG THAT GOES TO THE RECEIVER AND TAPE OR HEAT SHRINK IT TO SO IT DOESN'T SHORT TO ANYTHING.
Ev1er
08.05.2008, 09:02 AM
I understand bit how do i solder the positive bec wire to the positive esc wire???? Can anyone tell me what do i need connection bullets for when soldering 8.4v battery lacks?? Please help me quick :)
azjc
08.05.2008, 11:57 AM
wrap the bare ends of the 2 wires together and than solder that to the connector and than put a piece of heat shrink tubing over the connection use a heat gun to shrink the wrap (cut and slide the tubing over the wire before you solder)
1maxdude
08.05.2008, 02:29 PM
I ran my cc bec wire along side my power wires on the mm. Then soldered both the mm power wires and cc bec wires to the battery plug together. It's a bit hard to get the shrink tubing to fit over everything, but it does with a little work. I then ziptied the cc bec and mm power wires together so they don't try to come seperated and yank out at the end. Also, there are places that sell pre made dean's Y adapters to wire in 2 batteries in either series or parallel, whichever you prefer. That is if you are using dean's plugs, not sure since you mentioned bullets. Or you could look at one and make your own harness. And as already mentioned, make sure you pull the little red wire comin off your mm that goes to the rx out of the wire harness and you should be set.
