08.17.2008, 08:37 PM
Originally Posted by MetalMan View Post
Was the drag brake on the MGM set? If not, that could explain excessive heat in the MMM and 9XL.
This is the reason why CC doesn't rate their car ESCs for current anymore. There's no standard for the ratings.
There was a drag brake on both controllers...don't remember the setting of the MGM, the MMM was at 30% I believe.
To lower heat on the motor I will reduce timing to 0, remove drag brake. Do you think that I can lower batt. temps. using the mmm?
