08.26.2008, 08:51 AM
It should work if you just save to desktop and when you run the install package select "run as admin" - I then set the shortcut to "run as admin" - I shouldn't need to set the compatability to XP.
However it only works with a MMM and a cc-bec however it won't install the HID for a MM... Have you got it to work with a MM?
