Originally Posted by Arct1k
It should work if you just save to desktop and when you run the install package select "run as admin" - I then set the shortcut to "run as admin" - I shouldn't need to set the compatability to XP.
However it only works with a MMM and a cc-bec however it won't install the HID for a MM... Have you got it to work with a MM?
Aaaah! No, mine won't work with the MM for lack of the MM Driver.
It only works with the Monster as of right now.
Is there a place where we can download the MM driver and do a manual install of the driver?
