Thread: E-Slayer Build
09.15.2008, 10:03 PM
Since the Slayer is built on the Revo platform, the CoG is a bit higher than ideal. The Revo even rolls unless you make it sit fairly low and/or use offset tires, and the Revo is quite a bit wider. I would lower it and use sway bars if cornering stability is your concern.
