Originally Posted by jayjay283
if you get rid of those supports I dont see why not, except the battery side is kind of nice offset for a little more room
also a guy said, the original lst (skinnier) axels are the same as the centers on the muggy and lst2 (but longer) if you wanted to extend it but use same stuff and cheap
Jay that is a great tip! thanks man. So you are saying other then lenghth they are exactly the same? that is awesome
Do you know the difference?
Thanks for the tip! good info I may use....
just noticed you said skinier.... May not work this will be a very high power app.... how much skinier? thanks :)
Heath
