CRTIM
10.04.2008, 01:44 AM
Originally Posted by cheesecake View Post
take the pinions and remove 2mm off of the end that atatches to the shaft also the shimming in the diff case shoule be 3 shims ring gear side and 1 shim on the other side. the gears woill feel notchy when you first build them but after a couple runs they should be butter smooth
Thanks a ton cheesecake....appreciate all the help guys
