cheesecake
10.04.2008, 01:15 AM
take the pinions and remove 2mm off of the end that atatches to the shaft also the shimming in the diff case shoule be 3 shims ring gear side and 1 shim on the other side. the gears woill feel notchy when you first build them but after a couple runs they should be butter smooth
CRTIM
10.04.2008, 01:44 AM
Thanks a ton cheesecake....appreciate all the help guys
cheesecake
10.04.2008, 02:09 AM
not a problem i used to own 2 crts so i know quite a bit about them.
CRTIM
10.10.2008, 04:32 PM
hey guys ...i finally am in the process of installing my HB ring and pinions .....i'm installing now but not sure of the shim placement ...where do i use the 8x10 shims ??..on the pinion shaft ?.....i was following the CRT manual book and they just show the 13x16 shims between the bearing and gear case (are those the ones that you guys are saying 3 to one side and 1 on the other)..?? thanks for helping with such noob questions
