Originally Posted by SV6000
After sorting the brake issue out today i decided to go down and practice. I set the throttle EPA to 50% (I havent driven in a long time) and started doing some easy laps. After about 5 mins the truggy jerked abit and than just stopped. "MMM Syndrome" I plugged it into the laptop to check the settings and everything there seemed fine, i responded to all the program commands, i even tried to update the SW again and that worked without a hitch. But when i tried to re-program the transmitter it wouldn't work at all. I would hold the trigger in the full forward position for the 2 sets of 3 beeps and wheni would move it to full reverse it would just beep once and that was it. If i tried to move my finger away from full reverse the truck would start driving forward. As if full reverse was neutral/Brake. I tried to use the transmitter to reprogram the ESC but it would not beep in the neutral position so it would not advance or change settings.
What is going on.
Have you tried to clear of the exisitng memeroy ??
IE have you done this:
You can always remove all programming from the ESC and start from scratch by simply turning everything off, then turn on your transmitter with the throttle on full throttle and then turn on your RX, let the ESC / motor beep 3 times (continue to hold it) and then it will beep or blink 4 times, now move the throttle to the full brake position in 3 sec and the motor / ESC led will blink / beep and then shut it all down and simply start @ step two again..
This thread might help.. ???
http://www.rc-monster.com/forum/showthread.php?t=13544
Best of luck and let us know if that helped :
