SV6000
SV6000's Avatar
10.06.2008, 05:55 AM
After sorting the brake issue out today i decided to go down and practice. I set the throttle EPA to 50% (I havent driven in a long time) and started doing some easy laps. After about 5 mins the truggy jerked abit and than just stopped. "MMM Syndrome" I plugged it into the laptop to check the settings and everything there seemed fine, i responded to all the program commands, i even tried to update the SW again and that worked without a hitch. But when i tried to re-program the transmitter it wouldn't work at all. I would hold the trigger in the full forward position for the 2 sets of 3 beeps and wheni would move it to full reverse it would just beep once and that was it. If i tried to move my finger away from full reverse the truck would start driving forward. As if full reverse was neutral/Brake. I tried to use the transmitter to reprogram the ESC but it would not beep in the neutral position so it would not advance or change settings.
What is going on.
