RBMike
RBMike's Avatar
10.07.2008, 03:23 PM
I have 2 working V2's still. The one with the most hours on it (several weekend worth) is one that the fan connector broke off of the first day. I cut the "grill" section out above the fan so the blades could not catch on it & wired the fan to the RX. This V2 has performed flawlessly since I did the mods after the first day. My set-up is 5S, Neu 1512 3d/f,RC8 18/46 gear. The other one only has a couple of hours on it. It still is using the stock fan & connector but I cut the grill out of it. I also carved some clearance in the case around the connector & but I'm thinking of busting the connector off the board on purpose. On both V2's I have put shrink tubing on the big plug sockets to keep them from shorting on the heat sink. I did have 2 earlier V2's fail but they were not modified (failed on the same set-up).
