drkdgglr
10.15.2008, 04:08 AM
Originally Posted by Unsullied_Spy View Post
but adding cells for voltage gets heavy and takes a lot of room.
As I understand, if you go for higher voltage and lower kv, you can get lower capacity amp packs. With 5s5000mah packs you should get about the same runtime as with 10s2500mah packs (both setups geared for the same speed). So the weight of the batterys should be about the same.
