Originally Posted by rchippie
Im looking for a few opinions, i just want to make sure i dont get the wrong motor. As some of you may or may not know i pre ordered a MEDUSA 70mm 2300kv motor to run on 4s in my GTP . Is this the right choice or should i get the 2000kv motor instead ?. I have recived a few opinions via pm's, & im looking for a few more . Thank's
The 2300Kv is good for 4S lipos as 300Kv isn't much when using such low voltage
. I would have gone higher voltage, but if you insist on 4S then it's a good motor. It'll be spinning at around 34000rpm so it won't be running too hot, but that will also depend on your gearing.
