10.22.2008, 04:43 PM
Originally Posted by bustitup View Post
LOL...I wish you lived closer Linc........so I could watch you trying to keep up with my converted Revo with V-twin Vxl's......my main concern would be to try to steer clear of all the broken parts flying off your truck....bwhahahahahah
if by some fat chance you can catch me...I will just pull out my vxl esc's and put in two mm's and run 2 x 4s batts
whoooo hooooooo .......praise the V-Twin Revo unstopable and unbeatable..cheaper faster, more dependable
Neil...sorry dude twin vxl's are not a fad...there a religion...bwhahahahahahah
Wow, this is an interesting post. I had to check and make sure that I was on Rcm and not the traxxas forum...
First off, you claim that you will be dodging parts coming off my truck... Are you questioning my assembly skills, or claiming that revos break easily? You also have a revo so that would be a stupid thing to say.
Judging by your build thread you are running maxamps packs. Need I say more...
Also, a 1521 will produce more power and torque than the 2 S can feigao motors you are running (that is what those velineon motors are so don't bother arguing with me). That will allow me to gear higher than you. Plus I will not be running fans on my motor to keep them going...
A 1521 should be able to easily output 2000watts. I highly doubt that a s can feigao can put out 1000 watts, 600-700 would be more likely. Also your batteries are not likely to put out 1000 watts each...
You are running the old emaxx tranny in your truck, not as strong as the new erevo/emaxx tranny. I know that the old tranny would not be able to handle the torque output of the 1521.
I doubt your v twin esc/motor/fan/lipo setup was cheaper than my MMM/1521/polyquest setup. I have a feeling they were about the same.
I will also be running 1/8 scale diffs in Mike's hybrid cases, going to be alot stronger than your stockers...
Honestly your thread is quite poor, and just sounds like someone who does not really understand brushless or have much experience with various setups. I have owned most of what is available and will stick to a neu/mmm.
I will be more than happy to do some speeds runs and a 20 min bash session with you. Just unplug those fans on the motors and we will see who fails first...
