marzac2
marzac2's Avatar
10.23.2008, 03:41 AM
I run the stock set-up.
If your track has a lot of big jumps, bottoming out can be prevented with a heavier wt. oil. Try 50wt all around.
Try using a heavier center diff oil as well to prevent the motor from unloading to the front. Did you say you are running 10,000 in the middle? Thats already pretty high. May try 12,000, but this may be too much.
Z.
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
