Originally Posted by billy gunn
I was thinking of running 12s normally and just running 18s for speed runs and such, assuming I could find a controller that would handle the voltage.
Lutach, please PM me info/pricing for the Jeti controller, if you don't mind. I am still working on the electronics parts, and probably won't be buying anything until this winter. But I am interested in it.
You can make your car go fast with 12S and 14S. If you intend to use 18S, I would consider that set up for higher run times instead of speed. I was going to use a SHV Castle esc in a 1/8 scale F1 with 20S A123, but it was to basically show everyone the concept of the higher the voltage the more efficient everything runs and that's when long run times comes into play.
PM sent regarding the Jeti Spin200.
