MetalMan
MetalMan's Avatar
11.05.2008, 02:24 PM
Originally Posted by Klausen View Post
I am about to convert my CRT1 as well. I will probably buy Mikes motormount and batterytray, and run it on 4s lipo and a 8XL. Can you tell me what pinion size I should go for?
First off, will you be running the stock spur gear or will you convert to the 46t spur gear (from the X1-CR buggy)? If you stay with the stock spur (62 teeth), an 18t pinion would work well. If you are running a 46t spur, the smallest pinion Mike's mount will let you use is 14t (mine is using 14t).
Originally Posted by DickyT View Post
Looks good Metal Man, now go get it dirty!
Hah, gotta receive my MMM V3 first . CC received my V2 last Friday.
