11.19.2008, 04:58 PM
Thanks auto2. I only had one problem running 4s on a mm with the auto setting. I had a maxamps swell up on me. Don't know if it was just it's time or had anything to do with the cutoff set at auto. I am going to set the setting for 4s on the mm just in case.
Can anyone confirm if the auto setting work on 4s with a mm?
You other RCMers out there that use 4s on your MM's. What lipo setting are you running the auto or something else?
Maybe one of the CC guys can give a definate answer to this.
Thanks for the input.
