Thanks auto2. I only had one problem running 4s on a mm with the auto setting. I had a maxamps swell up on me. Don't know if it was just it's time or had anything to do with the cutoff set at auto. I am going to set the setting for 4s on the mm just in case.
Can anyone confirm if the auto setting work on 4s with a mm?
You other RCMers out there that use 4s on your MM's. What lipo setting are you running the auto or something else?
Maybe one of the CC guys can give a definate answer to this.
Set the custom cut of. The auto lipo setting is to low IMO anyway. It sets it for 3v/cell. Thats too low. I would set a custom setting for at least 3.2v/cell to keep your lipos healthy and happy. for 4s 12.8v/cell in the custom setting.
to make it...
or break it...
One question, you does my MM cut off when my 2s battery gets to about 6.6-6.8v (3.3-3.4v per cell) when it's set to cut off at 6.2 (3.1v per cell)?
Proabably becasue when its under load the voltage drops down to the cutoff voltage and when you stop running the voltage comes back up a bit when the battery is not under load.
to make it...
or break it...
