jordan...
one.five.two.seven
11.24.2008, 08:59 PM
Your truggy is supposed to be fast. Is anything binding on the drive train? My BPP with the 1521/1Y had an issue like this and it was my fault as I forgot to shim the diff. The ESC (Schulze 40.160) got hot which is kind of unheard of. As for the fan, you can mount your ESC so the heat sink is not facing down and that way it'll allow you to mount the fans.
I'll check for binding, but all the diffs and things were shimmed pretty well before i started. I'll check again though, it should just roll freely when i push it along right?
I have a question- what pinion are you running with the 42t? spur gear- I think I saw an 11t item back along?
I'm running a 16t pinion, on the calculator has an adjusted speed of 75mph. Unfortunately this is the only BL motor i have, im going to bring the laptop out with me today hopefully (if the weather stays good) and tweak some things and see how that affects the performance.
Do you have the timing set right? Do you have the ESC set for race mode (I think that's one of the setting, it's been a while lol)?
For the timing setting, i've just got it on auto. Im not to sure what the 10*, 20* etc. would do so i just left it for the first run. What timing do you guys normally run? There is an option for race mode, but that means you cannot use the LVC feature, so i didnt want to risk my lipos. I'll check the timing and frequency and things like that today.
I was thinkning last night, cool motor and hot ESC = overgeared right? But if it is normal motor and hot ESC, does that mean the problem lies somewhere else? Im going to solder the ESC and motor together today to get rid of some dodgy connections i have there and see how that goes.
cheers for the help guys, i'll keep you posted on the testing.
jordan
