11.30.2008, 11:08 AM
You have to solder the two pads together or use a small loop of wire to connect them. Or the mm will not be on.
Right now there is a small dab of soldier on the board where the 2 wires are supposed to be soldiered to, nothing more. So you are saying that if I connect the contact points at the board w/soldier it will work? Or would a small loop of wire connecting them be better.
