11.30.2008, 12:55 AM
You have to solder the two pads together or use a small loop of wire to connect them. Or the mm will not be on.
11.30.2008, 11:08 AM
Right now there is a small dab of soldier on the board where the 2 wires are supposed to be soldiered to, nothing more. So you are saying that if I connect the contact points at the board w/soldier it will work? Or would a small loop of wire connecting them be better.
brushlessboy16
brushlessboy16's Avatar
11.30.2008, 11:23 AM
as long as they are connected the esc will be "on" all the time
11.30.2008, 11:28 AM
That's fine....just didn't want to fry the esc that's all...better to ask and be sure! Thanks for your help
Not having to deal with any more switches will be better also!
11.30.2008, 12:59 PM
Magman- it's solder. No "i". Solder. Pronounced sod-er. What you are referring are the people that are overseas fighting for, well, freedom, I guess. I know, I shouldn't pick on someone for spelling, you just did it 5 times so I know it's not a typo, and I'm trying to save you some embarassing looks when you go to radioshack to buy "soldier"
11.30.2008, 01:05 PM
Thanks...that's what I get for not paying attention to detail...I try hard not to misspell words but, even in going over each response before posting, I still miss things from time to time....thanks for the correction!
11.30.2008, 05:22 PM
Good, as long as you dont pronounce it like some weird frenchman, sort of like "sodiee"
