ssspconcepts
ssspconcepts's Avatar
12.14.2008, 11:56 PM
Originally Posted by dangerwr View Post
Are these the Spiders you are using?
http://www.amainhobbies.com/product_...ducts_id/24323
http://www.amainhobbies.com/product_...ducts_id/24324
Not exactly cheap! I think I can find them on eBay for a bit less. Not sure but will probably run the stock ones in the F/R but replace the center diff with a Spider. You mentioned there was a fit issue or is it a direct fit?
Those are the ones. If you drop in a center diff, you will have to replace your rear center drive shaft with a different size...I have a spare if you need it.
