Originally Posted by ssspconcepts
The stock diffs were plenty robust...I had a spare set of the spiders. I figured I'd use the spiders since I had them handy and they are smoother than the stockers. Not exactly sure, but the car is probably 10-15% lighter than the Jammin buggy-IMO. It is considerably lighter than my BL Jammin CRT, which is set up with the same conversion stuff.
Are these the Spiders you are using?
http://www.amainhobbies.com/product_...ducts_id/24323
http://www.amainhobbies.com/product_...ducts_id/24324
Not exactly cheap! I think I can find them on eBay for a bit less. Not sure but will probably run the stock ones in the F/R but replace the center diff with a Spider. You mentioned there was a fit issue or is it a direct fit?
