dangerwr
12.15.2008, 12:19 AM
Originally Posted by ssspconcepts View Post
Those are the ones. If you drop in a center diff, you will have to replace your rear center drive shaft with a different size...I have a spare if you need it.
Thanks! I will let you know once I actually get down to it. I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
