Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
dangerwr
12.15.2008, 12:19 AM
Originally Posted by ssspconcepts View Post
Those are the ones. If you drop in a center diff, you will have to replace your rear center drive shaft with a different size...I have a spare if you need it.
Thanks! I will let you know once I actually get down to it. I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
ssspconcepts
ssspconcepts's Avatar
12.15.2008, 02:38 AM
I don't know yet...
My preference is to use either center diffs or trannies with a slipper. Mike's slipperential...when it is released...will do both!
To answer your question...you can simply install the collar that comes with that center solid shaft on the DM-1 stock 2-speed. It should work fine....when you get to that point there are plenty of members here that can help.
ssspconcepts
12.15.2008, 11:38 PM
Latest progress:
From DM-1 Spec
From DM-1 Spec
12.16.2008, 01:13 AM
...I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
I personally like the solid shaft. A center diff unloads too much and spins the front tires unnecessarily and you lose power. Unless you put really thick oil, and then where is the benefit? Maybe on a track where cornering is vital, but these have so much power that it's easy to drift around the corner if you want to turn tight.
I don't know what benefit a torsen diff (if that's what you mean by "spider") would offer. I can see using it in the front or rear to keep one side from unloading on corners. But the combination of stiff suspension and sway bars helps that a lot. Otherwise, it kinda acts like a solid shaft if used in the center...
rchippie
rchippie's Avatar
12.16.2008, 01:19 AM
That looks great . I almost got that car instead of my gtp . Does the battery hang of the chassis much ?.
REAL MEN RUN BRUSHLESS
ssspconcepts
12.16.2008, 02:18 AM
It is a really nice kit car...I am continually impressed with the quality of the Ofna products that are available. I guess about 1/3 of the battery hangs off the chassis. The is probably too much for your comfort as I recall from your previous posts a long time ago...but the tray is delrin, and this is a street racer, and everything is bolted down nice and tight...
rchippie
rchippie's Avatar
12.16.2008, 02:29 AM
your probably right . Since it's a onroad car as long as your tray is securly mounted it should be all right .
ssspconcepts
12.16.2008, 02:24 AM
I used 90wt diff fluid (which was the thickest that I had on hand). I am going to try the diff and then try the center spool. I just wish somebody made a heavy duty center slipper to go with that solid shaft....
12.16.2008, 10:50 AM
....I just wish somebody made a heavy duty center slipper to go with that solid shaft....
Yeah, that would be nice. But believe me, the tires slip enough. Seriously, I don't think the lack of a slipper is a big deal. Other than controlling take-offs, the other use of a slipper I can think of is to absorb drivetrain shocks when landing from jumps. Do you plan to jump this?
ssspconcepts
12.16.2008, 02:42 PM
Those are good points...no jumps planned for this car. I am going to give it a few runs as is. If it diffs out too much and eats the front tires I will definitely swap for the solid center spool. I just did not want to keep the 2-speed because I NEED reverse and I used all of these parts (center diff) because I had them on-hand.
speedracer1129
12.16.2008, 11:32 PM
Are you sure you used the right oil??? That there is shock oil, no good for diffs!!
Nuclear
California, Redwood
12.17.2008, 01:25 PM
Hello, winter project. just wanted to know, can you list the price of all your parts you used, including price of the car....esc...motor....etc....
thank you.
Ryu James
Ryu James's Avatar
12.17.2008, 02:54 PM
hey,
that is a sick looking project! let us know when you run it and how it does. any chance of a vid? have you done the body yet? if its the same quality as the build it will be awesome i'm sure.
Jammin SCRT10 Neu 1512 1y
ssspconcepts
12.17.2008, 11:18 PM
hey,
I will definitely get a vid for you all...eventually.
As for a body...I am planning to contact Team3six to see what he can do for me. Any cool ideas on themes? I was thinking something associated with Tesla or maybe nuclear energy.
ssspconcepts
12.17.2008, 11:12 PM
thank you.
I bought a lot of the parts over a long period of time when they were on sale or when I had some good coupon codes...but as an estimation:
$329 DM-1 Spec
$50 RC Monster motor mount
$75 RC Product Designs battery tray and diff top plate
$125 three Ofna Spider Diffs
$270 MMM and Neu Castle 2200kv combo
$100 JR Servo
$285 Flightpower 5S 5000mah battery
$85 Spektrum transceiver
$95 HPI D-Box gyro (not pictured)
YIKES it adds up quick.
