ssspconcepts
ssspconcepts's Avatar
12.15.2008, 02:38 AM
Originally Posted by dangerwr View Post
Thanks! I will let you know once I actually get down to it. I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
I don't know yet...
My preference is to use either center diffs or trannies with a slipper. Mike's slipperential...when it is released...will do both!
To answer your question...you can simply install the collar that comes with that center solid shaft on the DM-1 stock 2-speed. It should work fine....when you get to that point there are plenty of members here that can help.
