12.16.2008, 01:13 AM
Originally Posted by dangerwr View Post
...I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
I personally like the solid shaft. A center diff unloads too much and spins the front tires unnecessarily and you lose power. Unless you put really thick oil, and then where is the benefit? Maybe on a track where cornering is vital, but these have so much power that it's easy to drift around the corner if you want to turn tight.
I don't know what benefit a torsen diff (if that's what you mean by "spider") would offer. I can see using it in the front or rear to keep one side from unloading on corners. But the combination of stiff suspension and sway bars helps that a lot. Otherwise, it kinda acts like a solid shaft if used in the center...
