mohanjude
Need for speed
mohanjude's Avatar
01.06.2009, 05:32 PM
Originally Posted by E-VO-Maxx View Post
Using a pretty similar setup with slightly less power my first hints would be to choose a shorter gear ratio and to use real high-amp connectors between Lipos and ESC (6 mm gold)!
As you know I'm driving the FG 4WD with a Lehner 3040/12, Schulze 32/170 and 8S2P (12 Ah). The weight of my monster is "only" 15 Kg but from my point of view the pinion or gear ratio is key in this weight-league.
The general problem of brushless-setups in such heavy cars is to overcome the initial startup due to the missing clutch. I could see from your pictures that you are using the original pinion (16/48). Try 14/48! It's only two teeth less but it makes all the difference.
Another way to prevent stalling might be to change the throttle EXPO in your RC. Just put it to + 100% and check it out. I am down to + 50% but I still use it.
Compared to the 40.160 the 32.170 only works up to 10S but it can face higher Amps. (up to 220 peak) and you can set up things like higher or lower timing and softer or harder running. I tried all those switches but they didn't have big effects.
As mentioned, key is the appropriate gear ratio.
The Schulze ESCs have a kind of self protection once they face a situation that they can't cope and they just stop to work - other than the BKs that try to do it until they burn (and I know the smell of burned BKs...).
BTW. 150 Amps. is by far not sufficient and that's the reason why I haven't used eagletree yet. At least at 8S you have to think about 200+ Amps. at the start.
Regarding the 4WD-thing I'll send you a message.
Last but not least I don't want to make you jealous but with the 3080 your monster should at least performe like mine:-)
http://www.youtube.com/watch?v=mZQR_Xubr8o
Regards,
Hermann
Hermann
Thanks for your detailed message. Did you read my bit about putting the motor on the bench and holding the shaft with my finger. I am not talking gears here - just my fingers. With the Schulze when the timing signal is increased to 0.154 (neutral is 0.150) the motor stalls. If I go straight to 0.157 then the motor will not stall. I will try expo which means that the motor will jump straight to say 0.160.
You are right about the BK's - I just love when I can smell them. I feel my wallet just going up in flames. What did you think of the Bolido? You dont think it is powerful enough?
Next week when Lehner opens his shop again I am going to ring him and ask what ideas he has.
My truck runs fine on the current gear ratio using the Plettenberg Bolido and the schulze controller. Why can't it run better on the Lehner 3080 which is a bigger more powerful and heavier motor.
I might be tempted to return the truck to the Lehner with bigger wires and bigger 8mm power connectors.
Mohan
