E-VO-Maxx
01.06.2009, 05:22 PM
Using a pretty similar setup with slightly less power my first hints would be to choose a shorter gear ratio and to use real high-amp connectors between Lipos and ESC (6 mm gold)!
As you know I'm driving the FG 4WD with a Lehner 3040/12, Schulze 32/170 and 8S2P (12 Ah). The weight of my monster is "only" 15 Kg but from my point of view the pinion or gear ratio is key in this weight-league.
The general problem of brushless-setups in such heavy cars is to overcome the initial startup due to the missing clutch. I could see from your pictures that you are using the original pinion (16/48). Try 14/48! It's only two teeth less but it makes all the difference.
Another way to prevent stalling might be to change the throttle EXPO in your RC. Just put it to + 100% and check it out. I am down to + 50% but I still use it.
Compared to the 40.160 the 32.170 only works up to 10S but it can face higher Amps. (up to 220 peak) and you can set up things like higher or lower timing and softer or harder running. I tried all those switches but they didn't have big effects.
As mentioned, key is the appropriate gear ratio.
The Schulze ESCs have a kind of self protection once they face a situation that they can't cope and they just stop to work - other than the BKs that try to do it until they burn (and I know the smell of burned BKs...).
BTW. 150 Amps. is by far not sufficient and that's the reason why I haven't used eagletree yet. At least at 8S you have to think about 200+ Amps. at the start.
Regarding the 4WD-thing I'll send you a message.
Last but not least I don't want to make you jealous but with the 3080 your monster should at least performe like mine:-)
http://www.youtube.com/watch?v=mZQR_Xubr8o
Regards,
Hermann
