Ryu James
Ryu James's Avatar
01.09.2009, 07:56 AM
Originally Posted by himalaya View Post
Yes, this is a great idea. Actually the straps are going underneath the epoxy deck, the CNC machined grooves on the Tekno chassis provide channels for the straps.
Problem here is my deck has no side walls, without strong hold down force the batteries will slip back and forth during running and jumping, hit the steering post etc. Maybe I need Mike to make me a custom CNC machined battery tray.
you should totally have Mike make you a battery tray. i saw in another thread that he said he can literally make any size tray you want. he is only limited on it being 1" high sidewalls. but as far as length and width there are no limits. you could have a tray that runs the whole length of your chassis and fits both batteries. also it would be grooved for your velcro straps. it would look much nicer and work better and probably only cost you about $50. just put in your dimensions on the site where you can order custom size trays.
http://www.rc-monster.com/proddetail...erytray&cat=18
Jammin SCRT10 Neu 1512 1y
