01.30.2009, 12:25 AM
Originally Posted by SpEEdyBL View Post
I bet if you are sure one pack has less mah AND a smaller amp rating than the other, you can put an external lvc just on just that pack and not have to worry about the stronger pack going below the minimum voltage.
Problem with this is the setup will have to draw way lower than the smaller pack can handle. If it is even close to the smaller pack's cont rating that pack will most likely puff from over discharge. Just buy the right thing. 5s is a good voltage to run stuff at, but if you have to run 2 packs go with 6s.
