Originally Posted by azjc
I did some research on the motor and my guess is the electronics will be ok, I would be concerned about your drivetrain with the amount of torque that motor will produce and the amount of RPMs the motor is designed for (3500) but you never know untill you try...some of the most fun I have had with projects is trying something new
I am going to gear it at .84. It will have a 13t sproket pinion and an 11t sproket spur.
