Originally Posted by teknorc
Yeah, 'the locked in 2nd' is probably the cause of the excessive heat. Clutches need a certain RPM/gearing combo range to work properly and locking in 2nd takes the clutch out of that range. So if you want to keep the single speed, direct drive is probably the way to go.
We realize the clutch is not a perfect system, like lincpimp said, it's another option. Our new 3-shoe is pretty cool though and allows a greater range of the above mentioned RPM/gearing combos. With the thinner .7mm springs, it would probably work good on a single speed Revo.
A question on the new 3 shoe clutch system that I have is about clearance between the clutch bell and the center diff mount? On my 8T when using the Tekno RC clutch bell I have to dremel a little (not an issue at all) to ensure that there is clearance for it to spin. I noticed that a standard nitro clutch bell's diameter is larger, which causes me to think that I have to dremel a little more for. Does that sound right?
