Originally Posted by js058515
A question on the new 3 shoe clutch system that I have is about clearance between the clutch bell and the center diff mount? On my 8T when using the Tekno RC clutch bell I have to dremel a little (not an issue at all) to ensure that there is clearance for it to spin. I noticed that a standard nitro clutch bell's diameter is larger, which causes me to think that I have to dremel a little more for. Does that sound right?
That's exactly right. That's also the reason we went with the smaller clutch system in the beginning, because it fit in more places. Using the 44mm mount and a 13t clutch bell requires the most grinding while the 36mm mount or our new (yet to be released :) square can motors will provide more clearance. We've found that the Mugen and Losi required the slight mod, while RC8, Jammin and Hot Bodies more clearance.
