JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
02.05.2009, 06:52 PM
Originally Posted by monsterbaja View Post
What is the best connector for high volt Batteries.
(I am using 8s 4300mah)
Is deans the way to go.
Thanks.link please.
I beleve that most of the guys like Deans connectors for this purpose. Personally I prefer using the TRX connectors. They are a little bit bigger and they are much easier to plug and unplug in a hurry. The Deans are just too small for me and difficult to use. Both can be a little bit tricky to install PROPERLY if your soldering skills are still on the learning curve so to speak, and if you have never done it before. After installing a few sets on your own it gets a little easier. Practice makes perfect. Like most things it is a personal preference matter that you have to choose for yourself.
SUPERMAXX YOUR LIFE.
