What is the best connector for high volt Batteries.
(I am using 8s 4300mah)
Is deans the way to go.
Thanks.link please.
I beleve that most of the guys like Deans connectors for this purpose. Personally I prefer using the TRX connectors. They are a little bit bigger and they are much easier to plug and unplug in a hurry. The Deans are just too small for me and difficult to use. Both can be a little bit tricky to install PROPERLY if your soldering skills are still on the learning curve so to speak, and if you have never done it before. After installing a few sets on your own it gets a little easier. Practice makes perfect. Like most things it is a personal preference matter that you have to choose for yourself.
hey monsterbaja,
what is the latest with this project? i am interested to know. btw, the best connectors for HV setups imo are 8mm bullets avail. at cheapbatterypacks.com or on ebay on occassion. if you cant go with those go with the Castle 6.5mm bullets.
anyway, keep us updated.
Jammin SCRT10 Neu 1512 1y
Hey ryu,I am going to move everything over to the new FG Baja 4wd RTR.
So i am waiting on the car.
The competition one is just to heavy,to much alu.
Thanks for the connector tip.
