Finnster
KillaHurtz
Finnster's Avatar
02.07.2009, 06:51 PM
Well if you get extended axles, you will need extended a-arms as well. The longer a-arms are what give your truck a wider stance and more stability. The axles are needed only if you have wider arms as well.
no no..
Only the axle is`ext, You need axle and spacer. It does make it wider by 2cm or so. All comes as part 86249.
