Finnster
KillaHurtz
Finnster's Avatar
02.07.2009, 06:51 PM
Well if you get extended axles, you will need extended a-arms as well. The longer a-arms are what give your truck a wider stance and more stability. The axles are needed only if you have wider arms as well.
no no..
Only the axle is`ext, You need axle and spacer. It does make it wider by 2cm or so. All comes as part 86249.
JThiessen
JThiessen's Avatar
02.07.2009, 07:50 PM
This is what finnster was referring to http://www.hpiracing.com/graphics/ki...IMG_9135_e.jpg
Seems like a weak way to do it to me, but if it works, then its a very cheap and light weight way to get some extra width.
The FLux uses the same arms as the XL, X, and SS apparently. I did a search, and so far, nobody makes a wider arrm set (I didnt look at the FLM stuff yet...)
Personally, I think I'm going to try some full offset rims.
BitHed
02.09.2009, 11:52 AM
...yup same arms as the other Savages...
...have to agree that the XL axles DO look weak...
...you could also change to 8mm axles and use extended hexes there too...
