SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.25.2009, 09:35 PM
The 2200 with the gearing you use now with the 2650, will yield about the same results as just gearing down the 2650. Basically, increasing the length of a motor (as is the case with the 2650 to the 2200), is almost the same as adjusting the optimal range of pinion gears.
Area 52 Ranch Raceway
T.R.C.R.
