SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.25.2009, 09:35 PM
The 2200 with the gearing you use now with the 2650, will yield about the same results as just gearing down the 2650. Basically, increasing the length of a motor (as is the case with the 2650 to the 2200), is almost the same as adjusting the optimal range of pinion gears.
Area 52 Ranch Raceway
T.R.C.R.
jahno30
03.03.2009, 03:14 PM
If this is the case, then what do us new B's need to be doing to get a set up to run for 20-30 mins without blowing something up...
