New Problem
hoober
New Problem - 03.02.2009, 09:48 PM
Originally Posted by hoober View Post
I just replaced motor with a bigger, but slower one. As son as I get some weather I'll test it. I suspect it'll be fine until I gear it up to start making some speed. It's now geared to match the speed of the small 1500 kv motor.
New motor 1200 x 56 mm rather than the 50x1500 and the trouble is back again. Exact same trouble when using over 100 ft range.
Now I see sparks intermittently inside the rear of the motor on the bench test . I don't know much about bl motors, but that can't be normal, right? Funny thing is it will do it when starting up , but when running WOT on a bench it'll be perfect with no sparks.
