03.03.2009, 12:16 AM
I already said in another post that as a rule, Castle Creations does not comment on the performance, usability, fitness of purpose, etc. for other brands.
Besides, I don't have any "Zippy" batteries to test with. I haven't tested "Zippy" batteries. So I don't have any idea whether "Zippy" batteries are fit for the purpose of setups on the MMM. I would also imagine it would matter (A LOT!) what kind of setup you ran (pinion, overall gear ratio, etc.) that you ran (as it is with ALL batteries...)
My suggestion -- run the smallest pinion that gives you the performance you are looking for. And don't try to push anything too hard. At the power levels the MMM runs at, bad things will happen very quickly...
Patrick
Good advice...
Zippys are compareable to maxamps (performace, not price).
I would think that moving a 12+ lb truck at 60+ mph will require a larger mah 30c 6s lipo. I find my 4500mah fp 6s 30c lipo is being pushed hard in the lst (heavier than the flux), and it is geared for 45mph... Some of the new 40c thunderpower lipos look to be the best bet... I have a jet buddy (BVM) who has some of them and says that they are leaps and bounds better than the 30c fp lipos...
