Thread: Got an Emaxx
mkrusedc
NeuMaxx
mkrusedc's Avatar
03.04.2009, 12:10 AM
Something Went in the transmission.. was running out in the snow and watched a small fragment of something go flying out of the truck then had no power to the wheels. upon further inspection there is a gauge mark on the top of the transmission where a pin(i think) came out the top.. And now the top gear shaft and slipper can slide in and out of the transmission about 1/2 inch. I tried the truck out in 1st gear to diagnose, and found nothing, but in second the truck runs fine until the top shaft jumps out.. this leads me to beleive that the 1st gear roll pin came out..
What do you guys think.
Can i tell you that it is a PITA to get the trans out of an emax..
Sounds like the input shaft roll pin. Use a piece of an allen head wrench or a steel drill bit cut down to fit. That with steel idlers and your tranny should be rock solid.
