squeeforever
squeeforever's Avatar
03.05.2009, 02:29 PM
how so?
i had a 2.5 and i now have a platinum and they are the same
try losening the slipper alittle more and dont gun it or brake hard after landing a jump and they should hold up alot better
aluminum cases and the inner brace will help but the only other fix is the massively over priced FLM conversion
I'll bite...how so? I've been buying the same parts since day one - haven't noticed anything different.
I think Squee was correct, or maybe more that I was somewhat incorrect. The original 2.5R had an "I-Bar" set up in it. I dont recall my first one having that - but...one doesnt always recall everything! The 3.3 diffs are configured the same as the E-Revo, just some parts have an X designation, which may or may not mean something
Originally Posted by madmaxx View Post
the e-diff's are different from the nitro diff's, the e-diff's use a spider gear support bar
proper shimming of the diff is necessary for both e-powered/nitro IMO
i run shimmed, alu diff's with Robinson R&P
It appears you are correct - I had my pages mixed up, hence why I didn't recall seeing that support in there.
Looking at the exploded view, it appears that there is only one spider gear - is that correct?
Originally Posted by mistercrash View Post
The diffs of the nitro Revo and the ERevo are different. The nitro uses the TRA5381 diff case. The ERevo uses the TRA3978 diff case that comes with metal blocks for the spider gears' pin and to accommodate for the TRA5382X metal block that go between the two spider gears. These metal parts are what is supposed to make the diffs stronger and the EREvo diff case is different from the nitro one so that the metal blocks fit in it. There are two spider gears in the diffs but for some reason the exploded view only shows one.
Correct...For the most part. If I'm not mistaken, that support bar is now in the newer model 3.3 as well as the E-Revo, Slayer, and the T-Maxx 3.3 and E-Maxx 3905.
They pretty much all have it now I believe, but the original 2.5R and the old 3.3 didn't.
