mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
03.05.2009, 12:37 PM
The diffs of the nitro Revo and the ERevo are different. The nitro uses the TRA5381 diff case. The ERevo uses the TRA3978 diff case that comes with metal blocks for the spider gears' pin and to accommodate for the TRA5382X metal block that go between the two spider gears. These metal parts are what is supposed to make the diffs stronger and the EREvo diff case is different from the nitro one so that the metal blocks fit in it. There are two spider gears in the diffs but for some reason the exploded view only shows one.
No brain, no headaches.
