kevinlew211
03.11.2009, 10:55 PM
Originally Posted by DLS II View Post
I'm in the midst of an Evolva conversion myself. I took the 2-speed apart and used the larger of the 2 gears and the hub of the smaller gear (after turning it down) to make a set screw "spur gear" to go on the jackshaft. I glued the hub (jb weld) into the larger gear. I picked up a Novak 4.5 HV after seeing a Mugen with that system going every bit as fast as the gas cars were.(youtube) I sure wish I could find a diff for the rear! Don
I also saw that video, its fast, its belong to Rick from Empire Racing, do you have any idea what kinda gears set he was using, since he turning 72k rpm, of course stock gear won't do any good, btw, do you have to do custom motor mount too?
