Jeremy1976
03.14.2009, 09:20 AM
Originally Posted by Unsullied_Spy View Post
That's good enough for now. Seriously though, go with Rootar's advice and get the nastiest gears you can get. 32p will be fine and you can get 32p pinions in the 1/8th inch shaft and it will be leaps-and-bounds stronger than the 48p gears you're using now. With one of Mike's bore reducers you could run a Mod1 gear on there (should have gotten a 5mm shaft from the start but you live and learn) and a Revo spur gear. If you strip a Revo spur gear in an ER you've got either mesh or bearing problems.
Yes that is the plan! I got some 32 pitch gears coming and the bore reducer. Thanks for the reply.
