Monoblock
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Monoblock - 03.23.2009, 07:00 PM
Originally Posted by twisted8 View Post
i was looking into getting one of them nut thats almost 100 then another 20 or so for a drive shaft then i still need drive cups. might as well buy a chassis. (unless you havea used one for sale )
im running 60k in the front diff, went up from from what i was running and it is better. maybe programming the mmm and driving a bit more conservatively will help ?
or maybe i should go up on the pinion ? running 19/68 now.
the options are not depleted yet ! i was just looking for some inside info so i head in the rite direction.
The monoblock is still your best bet, because it is a move forward in improving your handling without going backwards in performance. The mono is like $65 and you can get drive cups there just as well cheaply, and then order the driveshaft from RCAlloys for $20 shipped. You already spent good money for the MMM combo, why compromise on anything else?
SUPERMAXX YOUR LIFE.
